Where is MAP sensor located?
Old Apr 19, 2012 | 01:39 PM
Steve Gawinski's Avatar
Hey guys i'm looking for the MAP sensor on my 88 Pontiac Trans Am 305 TPI
can you please tell me or send me a picture of where its at? Thanks
Old Apr 19, 2012 | 01:47 PM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
Re: Where is MAP sensor located?
I cant say for sure on your application, but on my 90 350 tpi, it is passenger side, rear, upper intake, just infront of the coil.
Old Apr 19, 2012 | 02:35 PM
1985WS6TA's Avatar
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
You don't have a MAP sensor on your car, 85-89 TPI didn't use that sensor since they were MAF controlled systems. 90-92 TPI were MAP cars or Speed Density and is located where Dark Ember said.
Why were looking for it in the first place?
Old Aug 22, 2012 | 08:06 PM
Max Charron's Avatar
i have a '87 trans am and he give me a MAP sensor error on OBD
Old Aug 22, 2012 | 08:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You need to know what type of setup you own ; MAP or MAF ( Ref post # 3 above )
The same error codes used on both setups
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_34.htm
http://www.chevythunder.com/map_code_33.htm
http://www.chevythunder.com/map_code_34.htm
Old Aug 22, 2012 | 08:13 PM
map and maf on 87 gta
Old Aug 24, 2012 | 12:53 AM
RRUHL's Avatar
Car: 92 RS
Engine: 350 5.7 TPI from 91z28
Transmission: 700R4 transgo shift kit
Axle/Gears: 84z28 Disk brake with 3.23s
you dont have a map sensor its prob a code for your maf infront of your tb intake set up for ur tpi
Old Aug 24, 2012 | 01:57 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Got a picture?
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 5, 2015 05:02 PM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
