Killing your car...not as easy as it sounds!
Old Aug 15, 2012 | 02:12 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
So I was going to tackle changing out the fuel filter today but I can't seem to find which fuse it is on my 87 Iroc. I was going to do the method of pulling the fuel pump fuse and then running the car to rid of all fuel and pressure in the lines so that I could safely remove it. So which fuse is it?
Old Aug 15, 2012 | 02:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Killing your car...not as easy as it sounds!
If you pull the fuel pump fuse car will not prime and i dont believe it will start. And if the pump is off any fuel in the line will not move to engine to let car run so that wont work like you describe. Only thing you can do is unscrew the filter and let excess drip out. Just make sure no siphon effect occurs and drains the tank
Old Aug 15, 2012 | 02:24 PM
Well damn then Chilton lied to me lol. Any tips to prevent said siphon effect?
Old Aug 15, 2012 | 02:31 PM
Mishimoto's Avatar
Just change it quick, don't decide to take up ballroom dancing or try to learn trig in the middle of it, and you should be fine. Wear safety glasses!
Old Aug 15, 2012 | 03:12 PM
torque_is_good's Avatar
Are you just changing the fuel filter?
a little kitty litter or an old bath towel is all you need.
Old Aug 15, 2012 | 04:19 PM
Yeah just the fuel filter.
Old Aug 15, 2012 | 04:36 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
remove old one and just put the new one old. No tricks needed!
Old Aug 20, 2012 | 12:40 AM
Doctrouble's Avatar
I definitely second the safety glasses comment. I got some brake fluid in my eyes a while back. Anytime i'm looking upward at any drip-able fluid.. i slip those on.
Old Aug 20, 2012 | 09:12 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
I've gotten gas in my eyes before from my LT1 T/A. The rail was still pressurized and it sprayed directly on my face. Press the shcrader valve in on the rail to release the pressure if your car is still fuel injected. Never had it siphon when I took the filter off. It drips for a few seconds and stops.
Your car is getting old, therefor it probably has surface rust under it. Totally use safety glasses, rust in the eyes sucks bad enough without any harmful fluids.
Old Aug 20, 2012 | 10:48 PM
poloaa008's Avatar
Old Aug 21, 2012 | 10:20 AM
Yes rust in the eyes sucks! I found that out when trying to pull the tab down on the underside of the car for my front fender. I was tugging away and the grips slipped off and I got a bit of rust to rain down in my eyes.
Ok safety glasses...got it
Old Aug 21, 2012 | 10:23 AM
Mishimoto's Avatar
I bet you used words that weren't even in the book when you got "rusted"
Old Aug 21, 2012 | 04:57 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes off to the eye Doctor I went with a scratched eye ball. He dug the rust out and gave me some drops to kill the pain. Didn't sleep very good for a couple of nights.
Old Aug 22, 2012 | 08:30 PM
Ha I sure did. I was pretty much rubbing my eye for an hour and a half or so until the pain went away. Then there were no more problems.
Old Aug 22, 2012 | 08:37 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
so you havent changed your fuel filter yet?
Old Aug 22, 2012 | 09:15 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
A little off topic but my dad is an excavator and somehow got a frozen particle of dirt jabbed into his eye a few years back... doctor nearly sh*t a brick lol.
Just remember, safety first. I know I'm probably like most of you guys and think "oh that won't happen to me" or "I don't have time to grab safety glasses/jack stands/etc". I've done a lot of unsafe or extremely stupid things (mainly in my earlier years of working on vehicles) and thankfully I am still healthy and in one piece. Truthfully, it takes longer to dig rust out of your eyes or go in to clean a serious wound than it does to go grab the proper safety equipment or tools.
Old Aug 23, 2012 | 02:23 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Try putting a gallon of gasoline down too hard and getting a dripping faceful of Gasoline in the eyes, nose, and your lips Lmfao I swear my face felt like cooking oil was running/ dripping, thats when I found out how refined gasoline is, I'm glad nobody lit a match at that time I swear I ran inside and washed out my eyes & face for 15 minutes with soap and after drying off with the towel, I swear my face felt crude after walking out, and somewhat reddish, all my buddies could do was laugh.
Old Aug 23, 2012 | 01:43 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Another tip for when you change a fuel filter... tie a rag around your wrist. That way when the gas drips out it won't drip down your arm into your shirt.
Good luck! Sometimes those things can be a pain.
Old Aug 24, 2012 | 02:09 AM
Not yet, they stepped up my hours at work so I have been busy. But hey more money to work on the car right?
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
corey8084
Sep 17, 2015 02:56 PM
cstrobel65
Sep 16, 2015 11:54 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Blue419
Sep 10, 2015 01:03 PM
