91 egr valve help
Old Apr 19, 2012 | 07:33 PM
mintc's Avatar
91 egr valve help
ok so i got me a code 32 today and found out its a egr code . so upon inspection i noticed there is not a vacum line on my egr vavle or laying anywhere around it, so the p/o must have bypassed it my question is where would i hook the vac line off the egr valve to? from the pics i seen it show to the egr silooid , wheres that at? , i have a 91 305 tpi
Old Apr 19, 2012 | 07:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 egr valve help
you don't state what year and engine you have.
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Apr 19, 2012 | 08:11 PM
mintc's Avatar
well i founf my egr solenoid and it only has one line hooked to it that runs to the drivers side rear of the intake , it dont show anything like that in the diagrams i think i got some jacked up routing, i found a blocked off vacuum line that comes out of a t by the map sensor
Old Apr 19, 2012 | 08:19 PM
Engine: Lb9
Transmission: M20
the vac siignal starts from the port under the tb on the drivers side to the egr solenoid to the egr. the solenoid is mounted on the ign coil bracket on the pass side rear of the intake.
Old Apr 19, 2012 | 08:35 PM
mintc's Avatar
so my next ? will be where can i find the vacuum line routing for the accesories
Old Apr 19, 2012 | 08:39 PM
Engine: Lb9
Transmission: M20
I posted the link you mean your hvac is the front port on the plenum bye the map. the next back is the fuel pressure regulator , than the map.
The other side rear is the vacuum booster.
Old Apr 19, 2012 | 08:57 PM
mintc's Avatar
yea mine is all messed up that explanes why my criuse probley isnt working. the link that you posted does not show anything about the cruise control vacuum or the t i got in mine. in front of my t it goes into a little plastic round thing, and one line coming out of the t is cut and blocked off
Old Apr 19, 2012 | 09:05 PM
Engine: Lb9
Transmission: M20
That's jacked up if your cruse control is vac operated.
Old Apr 22, 2012 | 07:11 AM
mintc's Avatar
ok so i found my vacuum diagram on my car, its different from the one posted on here, the cruise control and hvac run out of the same line, that was the one that had a t in it. changed that around and now my cruise works again. but my egr solenoid one has one vacuum port on it, shouldnt it have 2 one to the egr and one to the t.b.? i found a blocked off line at my t.b. but my egr solenoid has me scratching my head. im thinking it might be the wrong one, i found some online and the pic showed 2 vacuum lines on it
Old Apr 22, 2012 | 09:27 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
It should have a rubber adapter on the solenoid that accepts two small plastic hoses. The rear hole goes from the solenoid to the actual egr valve and the front most hole goes from the solenoid to the little nipple under the TB.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
