fuel line fittings
Old Apr 20, 2012 | 08:08 PM
andrew91fbird50's Avatar
Car: 89 Formula
Axle/Gears: 10 bolt 2.73
fuel line fittings
i wasnt sure where to post this at so i guess this is an acceptable place.
i want to replace my fuel lines and the new line doesnt have fittings on it. what size fittings will i need to use on the ends of the 25 foot lines i have. its tubing that i have to bend myself. i want to upgrade a little bit to a 1/2 inch line. can anyone please help me out?
heres the line im using http://www.summitracing.com/parts/SUM-G2512/?rtype=10
will someone send me the fittings and ends i will need to make this complete to mount up to the gas tank?
Old Apr 20, 2012 | 08:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel line fittings
Why do you think you need 1/2" lines with a 305" ; especially if you are using the stock line from the frame to the engine
If you go with 1/2" line you need -8AN fittings
Old Apr 20, 2012 | 08:31 PM
Car: 89 Formula
i dont need these for this engine. i need this for the 355. it wont be for another 3 or 4 months until i get everything together to do the swap. i want to make sure i have everything together before i pull my old engine and fuel system.
Old Apr 20, 2012 | 09:24 PM
ex-x-fire's Avatar
1/2" is still overkill for a 355. Upgrade the fuel pump for what you'll be running (carb or efi).
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
