After nearly 5 years I found out my 86 has a 5.7 and not a 5.0....
Old Apr 26, 2012 | 10:02 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
...not from the factory of course, but swapped! Tuesday I tried to do a tune up, spent all day trying to match up the cap and rotor that was on my car with a new one...no luck....UNTIL we looked up a cap and rotor for a TPI Corvette! I had to undo the emissions tube, but sure enough I was able to find the stamp that said 5.7. It was a pita to do, but wow how crazy.
Now I don't know how many miles it has, but it's still running so i won't worry too much.
Old Apr 26, 2012 | 11:01 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Re: After nearly 5 years I found out my 86 has a 5.7 and not a 5.0....
Congragulations on the new found engine
Old Apr 26, 2012 | 11:51 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Is there a stamp code for the 350? What do you have?
Old Apr 27, 2012 | 12:45 AM
conlinj's Avatar
the cap and rotor should be the same for a 350 or 305. The 85 and 86 used the large cap distributor, some part store computers try to sell you the small cap (87-92) style for those cars. Vettes always used the large cap distributor with tpi
Old Apr 27, 2012 | 01:21 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Yup. And a dizzy could easily be replaced so a cap wouldn't really tell you anything anyways.
Old Apr 27, 2012 | 01:59 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Exactly the same happened to me, my 86 TA 305 also turned out to be a 350, swapped by the PO. I thought it was just a carb conversion for the first 3 yrs I owned the car, but when I got the heads off - 4" bores.
I had already bought the gaskets for a 305, but wasn't really complaining
Old Apr 27, 2012 | 06:11 AM
Car: 1986 IROC-Z28
well that's what made us check haha, and it's now comfirmed. Thanks for the tips!
Old Apr 27, 2012 | 09:31 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Yes, look down behind the left head, it shows "5.7LG", where 305s have "5.0LG". Note that this doesn't apply to older blocks.
hectre13
Dec 11, 2023 08:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
