Knocking sound from 95 Lt1 (video)
Old Apr 29, 2012 | 12:18 PM
thulle's Avatar
Hi
I got a 95 engine that makes a knocking sound.
I can´t hear it at idle but the more i rise the RPM the more it sounds.
You can also feel distinct "vibrations" on the intake when it sounds, but it was hard to say where the sound comes from.
Here´s a video http://www.youtube.com/watch?v=t9Dlg6lXC8E
Is it a bearing that gone bad or could it be something else?
Were should i start?
//Mattias
Old Apr 29, 2012 | 01:36 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Knocking sound from 95 Lt1 (video)
does sound like rod or main bearing trouble...could also
check the torque converter/flexplate(if automatic)for
loose bolts,crack in flexplate etc.If the oil filter on the
engine has been in use a while,could cut that open and
look for failed bearing debris-copper or soft metal
shavings or particles. When pan is off,look for any rod
or main bearing caps that are black from heat of spun
bearing.
Old Apr 30, 2012 | 11:02 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Have you pulled the valve covers to check the push rods and rocker arms?
Old Apr 30, 2012 | 11:04 AM
thulle's Avatar
I took of the waterpump and saw that the bearing was bad, some of the ***** was missing.
but the engine still makes the knocking sound, the waterpump drive shaft has a pretty large play so I´m taking of the timing cover and will look if the bearing is bad on the opposite side of the waterpump drive shaft.
I found a good picture on http://shbox.com/1/engine_front_diagram.jpg
Old Apr 30, 2012 | 11:23 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Did you try taking off the serpentine belt just to make sure it isn't something stupid like the alternator or power steering pump?
Usually bad bearings do the opposite. They are louder at idle when oil pressure is low and get quieter and sometimes go away at higher RPMs. But I said usually as anything is possible.
One thing you can try to rule out rod bearings is disconnect one injector at a time and if one makes it go away or get quieter then you know that rod bearing is toast.
Old May 1, 2012 | 07:49 AM
Car: 1989 Camaro
Are you talking about the drive itself, or the shaft that fits over the top of it. There should be an o-ring on there that takes care of that.
Old May 1, 2012 | 12:17 PM
torque_is_good's Avatar
goose it and as it's coming down to you get the tell-tale knock-knock-knock-knock ? That would be lower end
In the short video you placed, it sounds like an accessory or even WP to me; however, you really only provided a few seconds of the sound.
Old May 3, 2012 | 10:52 AM
thulle's Avatar
Took out the engine and checked the bearings.
The third cyl rod bearing are bad and the crank has some heavy wear on it.
Old May 3, 2012 | 11:27 AM
LilSki's Avatar
Car: 85 Trans Am
That is exactly what my Vortec motor looked like when I took it apart. Looks like you got somewhat lucky and it didn't spin in the rod yet. I was doing my motor on the ultra cheap so I gambled and bought a new crank and put it all together with new cam bearings and rings. I got lucky as the motor runs smooth as can be without getting anything balanced.
New2Chevy
Sep 28, 2015 12:35 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
L0tuS
Sep 4, 2015 11:16 PM
tgp1990
Sep 4, 2015 06:24 AM
