Noob question
Old Apr 30, 2012 | 01:59 PM
ewskater92's Avatar
Car: 1986 IROC-Z28 Camaro
Engine: 350 carbureted (swap from 305 TPI)
Transmission: 700R4 rebuilt with shift kit
Noob question
well, I took my car apart and I dont know how to put the washer fluid system back together. My car was a 305 TPI engine. I took that out and put a 350 in with a carbed setup. Now I can't figure out how to hook up my window washer fluid. It looks like theres 2 vacuum lines coming out of something on my firewall, not sure what that something is.
Any help would be greatly appreciated.
Old Apr 30, 2012 | 06:55 PM
ewskater92's Avatar
Re: Noob question
anybody?
Old Apr 30, 2012 | 10:34 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Noob question
From your washer fluid bottle should have one vacuum line. That goes to the washer pump on your firewall, next to your wiper motor. Then a line goes from your washer pump to your wiper arm. There should be a T fitting off the line from the washer pump to each wiper arm. As for which fitting on the pump is suction and discharge, Im not sure. just plug the line from the fluid tank into each port one at a time until you have flow.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
