Distributor and timing
Old Apr 30, 2012 | 07:59 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Kinda simple. Took my intake off to replace gaskets. Marked the distributor in relation to the intake so it'd go in like it came out. Which it did, does it still call for a timing light? Only ask cause it gets warm pretty quickly. Everything checks out with no codes present.
Old Apr 30, 2012 | 08:19 PM
Re: Distributor and timing
What in the world for?
Just adjust it and see if you like the results. If you do, adjust it the same way some more. Keep doing that until you can't make it better any more. If not, put it back.
THE ENGINE doesn't need "a light" to know whether to run right. Neither should you.
Not rocket science.
Old Apr 30, 2012 | 08:22 PM
Not rocket science.
I don't think you read it right. I was asking cause the car runs but warms up rather quickly. I know timing can be an issue with this and was just curious since I pulled it out, but put it back in the same exact spot, if it needs to be hit with a timing light for proper timing.
That was all. No need to get all fancy here.
Old Apr 30, 2012 | 08:29 PM
And the "proper timing" would be ...... ????
And your timing mark is ...... how far off ????
So what happened when you advanced it?
Sometimes DOING stuff is more effective than arguing on the Internet.
Old Apr 30, 2012 | 08:33 PM
Thanks for the help but I'll pass on your input, which is barely anything.
Not worth the time. Carry on.
Old Apr 30, 2012 | 08:59 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i would use a timing light. what kinda ignition are you running?
but i understand what sofa is saying in so many words.
need a lil more info.
Old Apr 30, 2012 | 09:26 PM
I wouldn't bother with a timing light until AFTER the engine was running right.
Then I MIGHT, MAYBE, if I didn't trust my own ability to tell whether the engine was running right again later on, MAYBE, I'd look at it and see where it is so I could put it back. Although I think it's been prolly 30 or 35 years since I last did that, I suppose the urge could strike at any time.
All a "light" does, is blink. It doesn't tell you what "total" timing (what matters) THE ENGINE wants. It doesn't tell you how far the "low speed retard (aka "centrifugal advance") retards it at low speeds to avoid pinging and whatnot. It doesn't tell you haw far out of whack your timing mark is, which I'd almost BET MONEY, if I was the betting kind, that it's more than 5° off from reality. Even assuming your "mark" is right, and you set it to some random "factory spec", if YOUR ENGINE is the slightest bit diffferent from that one, or the fuel you run is the slightest bit different from what it was 15 or 20 or 25 years ago when that spec was written (YA THINK????), or your expectations are the slightest bit different from those of whoever wrote whatever "spec" you're reading, then setting it to some "spec" is doomed to failure.
Adjust it until THE ENGINE is happy, as measured by how YOU like it. You might have an entirely different set of criteria for "like" than me or someone else. "Like" might be defined by some combination of throttle response, power output, engine temp, fuel consumption, ease of starting, and who know what all else, that is NOT captured in some "spec".
Go out and DO SOMETHING to your car, and see if it makes it BETTER. Typing stuff on the Internet, calling me childish names, isn't going to make your car run any better.
Old Apr 30, 2012 | 10:42 PM
Never called you any names
Either way, I still think the WHOLE point is being missed here. Either I didn't explain it clearly enough or idk. I've put many many hours of work into this car and every so often I like to get on here and get help, suggestions. I don't have time to spend on here to make thousands of post. But I know what my issue is, thanks for all the input.
Old Apr 30, 2012 | 10:50 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
I would use a timing light. Start at 6 degrees.
Old Apr 30, 2012 | 11:35 PM
91bluez's Avatar
dizzy was out...flash her up and put a light on it!!!
warming up quicker than normal.....are the new gaskets the right ones?
are all the water jacket holes popped out of new gaskets?
sounds stupid and i mean no insult but was the thermostat put in the right way up?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
