poping and and no speed
Car: B4C
Transmission: Man 5
I but the accle 24lb inc on and now im blowing gas out the exhaust and it sounds like its missing. Also i have leaks in the exhaust.do i need a adjustable fuel regulator? or is there an under line problem?
(yes im a noob at this stuff
) Member
Car: 87 IROC Z
Engine: 5.7
Re: poping and and no speed
You need to have a new chip burned if you are going to use larger injectors. Your engine uses 19lb injector stock I think. Using an adjustable FPR isn't a bad idea either.
Steve
Steve
Elephantismo
Feb 13, 2019 12:51 AM
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
