white exhaust smoke problem
Old May 2, 2012 | 06:56 PM
Jesse Boggess's Avatar
Car: 1992 Camaro RS
Engine: '78 L82 bored .30 over
Have a 1992 rs with a 350 sbc with edlebrock 1406 carb. Recently bought a mallory 4309 fuel regulator. I have yet to adjust to correct psi...but regardless of how much pressure, the car has white smoke that smells like fuel blowing out of dual exhaust. Timing is set by ear, no misses. but when the engine runs off of primed amount of fuel...it doesn't have white smoke. Kinda stumped....oil is not milky and antrifreeze is clear of any oil mixture.
Old May 3, 2012 | 09:31 AM
Car: 1992 Camaro RS
Re: white exhaust smoke problem
Found out my #1 plug is not firing. Used a spark tested but it doesn't work. Any suggestions on what I should check to see if I'm getting spark? This may be related to the fuel smell but the smoke still has got me stumped. I have noticed a leaky header gasket. Has a bit of oil in it but I'm not blowing blue smoke.
Vintageracer
Jan 10, 2020 05:33 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
chazman
Aug 22, 2015 02:01 PM
Fronzizzle
Aug 17, 2015 02:52 PM
