Fan switch and connector too brittle from heat. Suggestions?
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I'm talking about the secondary fan switch on the passenger side. It is below my exhaust and I don't have the heat shields for my manifolds. The switch has broken off before and this is my second time soldering in a new connector. It gets too brittle to touch and I'm assuming it is from heat.
What can I do to protect this connector from heat? Is there something I can wrap it with? The exhaust temps don't seem to effect any other surrounding components.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Fan switch and connector too brittle from heat. Suggestions?
You could try spark plug boots
Something like this
http://www.amazon.com/Protect-Shield.../dp/B00178WH9G
Something like this
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 16, 2015 12:21 PM
