Vacuum Lines on modified engine
Old May 4, 2012 | 01:34 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I was wondering with my motor swap, where exactly do my vacuum lines go now? I have a Quick Fuel 680cfm carb, and it has 1 vacuum port. I also have a large threaded hole in my Summit Airgap manifold, which I'm guessing is for my vacuum on my brakes? Can I hook a vacuum manifold up to the 1 port on my carb, and run from the manifold to the vacuum advance on my distributor and my HVAC vacuum lines? I no longer have EGR, air pump, or evap canister. Am I missing other vacuum line connections? Thanks in advance guys.
Old May 4, 2012 | 01:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Vacuum Lines on modified engine
Vacuum advance on the carb port, PCV to the PCV port, HVAC and brakes to the intake port.
Old May 4, 2012 | 01:56 PM
Car: 1992 RS 6spd
I'm using a Filter where PCV would go, is this harmful?
Old May 5, 2012 | 10:24 AM
Car: 1992 RS 6spd
One last question, it's off topic, but I didnt want to start a new thread. I have an 85 series Mallory distributor, I wired the coil no problem, but there is a harness coming out of the base of the distributor itself with a red, black, and brown wire. I could speculate and start hooking wires up to this, but really, I have no idea what they're for, and my directions dont even mention what they're there for. Is this a connection for Mallory's version of an ignition box? Or am I hooking this up to an existing set of wires on my car. I know my old distributor had connections on it because it was computer controlled, but this one is not. I'm slightly confused.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
