305 l69 H.O Questions
Car: 84 camaro
Engine: 305 H.O
I have a lunati cam waiting to be installed, will i need any other parts to make this happen?, ive been told i'll need a roller timing chain, and new springs and rockers, is this true?, if so i'll order everything from lunati thanks again guys,
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 l69 H.O Questions
All you absolutely need is the cam, lifters, gaskets, oil and a filter, but there's a lot you can do while it's all apart.
Gotta have the cam and new lifters.
You'll almost certainly need the valve springs too; at least one of your stockers will probably break before you get backed all the way down your driveway with that thing.
Timing set, who knows,; when you get to where you can physically see your current one, you have to be the judge. I'm guessing .... you'll decide you'd like to put in a new one.
Other than that, it's pretty much a drop-in. At least in the short term.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
A double roller timing chain will require some modification to the block for clearance.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
