where to go next
Old May 5, 2012 | 06:14 PM
system155's Avatar
Car: 89 camaro iroc, 89 camaro rs
Engine: 350-iroc / 305 rs
Transmission: 700r4 / t5
where to go next
ok so i have a 89 camaro it has the 305 and switched the fuel injection to a carb and i have a major overheating problem along with when it heats up i have no power it will only let me get up to like 50 ml and up to 1700 rpm. i have changed the radator i have a 180 tem thermostat, new water pump changed the cat, and done a flush of the engine i dont no what to do next
Old May 5, 2012 | 06:19 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: where to go next
Is your fan kicking on?
Have you set the timing?
Old May 7, 2012 | 05:12 PM
system155's Avatar
all that kicked on just got done doing a compression test and found out that its a blow head gasket
