help 5.7 tpi wont start
Old May 8, 2012 | 08:50 PM
Ndb's Avatar
Ndb
I have a 1991 gta trans am, it is an automatic.
it will not start ,u can spray fluid down the throat and it will run as long as u do that.
i have replaced All sensors inlcuding oil and temp, i have no security light coming on, so i do not beleive it to be Vats. any ideas? o i have replaced all ignition parts including distributor
Old May 8, 2012 | 09:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: help 5.7 tpi wont start
you have spark , compression , air but are lacking in fuel. have you tested your fuel pressure? or hooked up a noid light to one of the injector leads to check four pulse ?
Old May 8, 2012 | 09:30 PM
Ndb's Avatar
Ndb
I have fuel pressure , I don't have noid tester , can a circuit tester work in its place?
Old May 8, 2012 | 09:52 PM
Engine: Lb9
Transmission: M20
you can check for power at the injectors with the koeo and will have 12v if you don't check inj 1 and 2 fuses. If you have a analog vom you may see the pulse when the engine is cranked. The ecm grounds the injectors to fire them. so you have one of four issues wrong, you verified correct fuel pressure so it would be a vats issue or a bad ecm or ecm ground behind the passenger cylinder head or no continuity back to the ecm from the distributor through the dist to d8 or d9 at the ecm.
Old May 8, 2012 | 09:57 PM
Ndb's Avatar
Ndb
Will check all that tomorrow and I will let you know , thank u
For the direction and I will let know results
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
