carter fuel pump
Old May 10, 2012 | 09:39 PM
christian89's Avatar
Car: 89 camaro rs
Engine: 350 ; edelbrock stuff and carb'd ha
Axle/Gears: stock
carter fuel pump
I remember seeing on here someone talked about a carter fuel pump, i was considering getting one since they're reasonably priced at 24$ (for the one i was looking at getting) and i like how it has a return, anyone have ever used this its a 120gph with 5.5-6.5 psi,btw i have an edelbrock performer 600cfm put bigger jets in recently here it is on summit http://www.summitracing.com/parts/CRT-M6626/ - are they dependable and is it worth my time? I'm pushing about 350hp (roughly) haven't dyno'd yet 6,000 rpm max, the pump on it now is gettin worn, loses pressure when reving and jus trickles fuel under 3,500 rpm, thanks for any insight on this
Old May 10, 2012 | 11:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carter fuel pump
The M6626 is about all the pump you'll ever need.
Old May 11, 2012 | 12:39 PM
Car: 89 camaro rs
Axle/Gears: stock
great, thank you
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
