won't start after sitting for a few hours
Old May 1, 2012 | 08:52 PM
camaroman9191's Avatar
Hey all, I have a 1991 Camaro z28 with the 305 tpi w/5 spd manual transmission. I have a problem that is starting to drive me nuts. I'm taking the car back out of storage for the last 3 years and putting it back on the road. I have already done plugs, wires, cap+ rotor, drained all the old fuel replaced with new. The car will start by itself sometimes.. It normally cranks and cranks and the fuel pump is priming and running while cranking. I also am pretty sure the fuel pressure is correct. If i mist a little fuel into the intake then crank it, it fires right away and will run as long as the key is on. It rev's freely and not sputtering. If i shut it off after running it will start back up right away. If i let it sit for about an hour, it will crank and crank only.. I don't believe that the problem isn't spark related because it fires right up as soon as I introduce fuel into the engine. Also, no trouble codes come up while the car is running. please help. thanks
Old May 11, 2012 | 01:48 PM
6cycbird86's Avatar
Car: 88 GTA
Engine: 5.0
Transmission: Manual
Axle/Gears: 3.45
Re: won't start after sitting for a few hours
Please Help,
I am having the same EXACT issue with my 88 5.0 GTA.
I only drive it about once every 3 weeks or so and keep stored in my garage with the battery disconnected.
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
