i cant get my idle down, please help???
Old May 14, 2012 | 01:17 PM
91formula-fbody's Avatar
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
ok im not sure but i think this is the problem, my old idle air control valve connector that plugs into it was old and brittle and broke when i disconnected it so i took one of of an old wiring harness. but when i swapped them out i didnt get the wires in the correct order and tried reseting the iacv and tps and had too close the tb blades all the way and back the screw all the way out to get it close but couldnt get it no where near 450 rpms when i was trying too set muinimum idle? does any have a pic with the colors and diagram for the iacv connector? any ideas why this may be happening
Old May 16, 2012 | 09:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: i cant get my idle down, please help???
Did you happen to damage any vacuum lines in the process?
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
