water temp sensors
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
water temp sensors
Am I correct that there are three water temp sensors on my camaro?
1 on the passenger side head
1 on the intake manifold near the thermostat housing
1 on the driver side head
Is it one for the dash gauge, one for the ECU, and one for the fan relay?
Engine: 4++,350 & 305 CIs
Re: water temp sensors
1 on the passenger side head (fan temp switch for dual fan cars, not sure on single fan cars)
1 on the intake manifold near the thermostat housing (ecm info temp sensor)
1 on the driver side head (dash gauge)
Car: 90 RS
I see, when I was searching for parts they just show up as sensors, but through BWD's website they show up as sensor, sender, and switch.
TFS4 - Switch to Radiator Fan
WT359 - Sender to Temp Gauge
WT3000 - Sensor to ECU
Thanks guys!
Thanks guys!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
