trouble wiring engine up NEED HELP!!!
Old May 14, 2012 | 03:02 PM
86irocdude's Avatar
Car: 86 iroc z28
Engine: 305 carburated
Transmission: 5 speed
I'm new to engines and this web site..... i have an 86 camaro iroc 305 carburated. i bought the car with no engine and just dropped one in. when put in the distributor set the timing and got her running with a spare carb yet when i hook up a 4 prong connector to the base of the distributor the engine suddenly dies and i cant start her up, when i unplug this connector she starts right up but i know i wont have any type of advance/retard without something connected to the distributor..right???? is there any way to fix this or should i just get a distributor with a vacumn advance???
Old May 14, 2012 | 04:26 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: trouble wiring engine up NEED HELP!!!
Maybe you have the wrong ECM for it (like the car had a 350 w/tpi, now u have 305 carbed,wont work.)
Could also be a problem with the comp
I dont think you can just drop in a vac advance dist, if the rest of your engine is comp-controlled and the dizzy isnt you'll have bad performance and fuel economy, it wont be running right
Old May 15, 2012 | 02:49 PM
86irocdude's Avatar
Car: 86 iroc z28
i know i was planning on stripping off the computer controls and putting on a non-computer controlled carb and then put the vacumm distributor on but now i have a computer controlled carb on the engine is htere any other connection to the engine im missing could that be why i cant get the orig distributor to work
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
