Intermittent starting issue help! please
Old May 17, 2012 | 12:46 AM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
so once again my camaro is giving me trouble......
okay sometimes it will start other times not.
so i tested the starter (jumped it) and ya it spins.
i traced the purple wire from the starter through the firewall to the clutch safety switch and THIS IS WHERE IT GETS WIERD!!
it splices into two wires, and one goes up into my dash and the other goes to my switch....
i poked around and found a third purple wire! WTF it comes from close to the door jam. its not connected to anything but it has some sort of terminal..
yet when i put the third purple wire in the starting relay in the empty spot it starts??
what do i do?
Attached Thumbnails Intermittent starting issue help! please-img_0988.jpg   Intermittent starting issue help! please-img_0989.jpg   Intermittent starting issue help! please-img_0991.jpg
Old May 17, 2012 | 07:14 PM
cha_chard's Avatar
Car: 89 Camaro RS
Re: Intermittent starting issue help! please
bump
Old May 17, 2012 | 10:34 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Well first off, somebody did a REAL shi**y job at splicing the wire lol
Ive found, as im sure alot of others would agree with this, that an intermettent electrical problem is usually a bad connection.
If you see where the third purple wire has a terminal, and it fits in the starter relay, and it starts like that, id say you found your problem.... Right?
Old May 18, 2012 | 12:53 AM
cha_chard's Avatar
Car: 89 Camaro RS
but the thing is, its not supposed to be there, there is no blade or anything.... and another thing, today i was messing around and it started without any messing around with that third purple wire...
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
