Camaro 92 z28 5.7 help please....
Old May 17, 2012 | 03:14 AM
Leonjz28's Avatar
Car: Camaro
Engine: 5.7 tpi
Hello thank you for looking i have a 92 z28 camaro 5.7 tpi that is given me problems it all started when i was driving on the freeway i floored it and it kind of bobed on me like if it wanted to turn off it wasnt over heating or anything so i just layed off the gas and it kind of went back to normal after i got off i came to a stop sign and it turned off so i turned it back on turned on like no problem kept driving every time i came to a stop it would bob and turn off or wanted to i got home parked it later i got back on the freeway and floored it this time it wouldnt go over 70 and all of the sudden it stalled out so i went on the edge of the road i turned back on it wouldnt go over 20mph if it tried to go faster it would start to stall out and turn off or the rpm would jus go crazy the crazy thing is if i would hit my power windows it would seem if the car would pick up.... Please help no check engine light on car starts fine every time i start it oil pressure is good it not the catalytic convertor i removed it....
Old May 17, 2012 | 08:20 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Camaro 92 z28 5.7 help please....
Could be anything. Has the fuel filter been changed recently? Could be plugged up. Fuel pump could be going bad. My 92 chugged really bad and it took me a while to realize it was the distributor. I replaced the entire unit with a new one and it ran great. Just some ideas for you to check out.
Old May 17, 2012 | 08:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Worth pulling the codes to see if anything recorded anyway
Old May 17, 2012 | 08:58 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
wild guess...the ignition module inside the distributor.
Old May 17, 2012 | 09:02 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My first thoughts are 1. ignition module 2. check your battery connections 3. fuel pump.
Old May 21, 2012 | 04:12 PM
Leonjz28's Avatar
Car: Camaro
Engine: 5.7 tpi
update i changed o2 sensor took a test drive worked good till was at 30mph started to bob down so i hit my power windows it came qlive 4 like 5 sec then started bobing so i let go can it b a short or my vss?
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
