91 camaro surges at idle
Old May 17, 2012 | 10:07 AM
fntoy91's Avatar
Car: 1991 RS
Engine: 350 TBI
Transmission: 5 speed manual
my tbi 350 surges 300 rpm at idle checked fuel pressure, 14 psi.,vac leakes, iac control egr valve, new plugs, new wires. Does anyone have an idea what might cause this?
Old May 17, 2012 | 08:51 PM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
Re: 91 camaro surges at idle
Had the same problem with my 305 tbi. Finally found the gasket under the tbi was cracked. Cured mine, might check yours.....
Old May 17, 2012 | 10:23 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Did you look for leaks? if so, how? or did you check the actual vacuum pressure? What was the results?
Does it do it worst when cold or hot? Ohmed injectors?
What was the results of fuel pressure test? How did you do it?
To me this seems a lot like a vacuum problem somewhere, just a matter of finding it.
jklein337
Sep 19, 2018 06:23 PM
db057
Aug 22, 2015 08:17 PM
jbd1969
Aug 17, 2015 07:06 PM
