engine pops, what causes it
Old May 20, 2012 | 08:41 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
got a 350 with a edlebrock 650 carb. It runs great when its cold out side but today it was 92 degrees and its popping at idle and while cruising down the road. If I accelerate using a good amount of pedal it clears up and runs awesome. What could i test or adjust(timing, carb, bad cam,???).
Old May 20, 2012 | 08:48 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: engine pops, what causes it
I think id check the timing just to be positive its correct.
Vacc leaks?
Could it be running lean/rich? Maybe try reseting the mixture screws, all the way in then 2 1/2 turns out as a "stock" adjustment. (remember how many times you turned them in, in case you decide to go back to that.)
How old is the carb and whens it been cleaned last?
Old May 20, 2012 | 09:29 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Timing. Rather wires are backwards, crossed, fuel issue or general timing issue.
Old May 22, 2012 | 04:35 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Im going to recheck the timing again. I timed it last winter and if i remember right it was more than 30 degrees advance. previous owner said it had a rv cam whatever that means. I have no idea where the timing needs to be exactly. i just turned the dizzy (while engine is running)to where it would start to run bad. Turn it in the direction to where it runs better and stop when it starts to run bad again. Then put it in the middle of those two points. whats a better way? or degree i should run with?
Old May 22, 2012 | 05:02 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
A better way is with a Timing light, check and see where it is now.
Steven 86IROC-Z
May 24, 2026 04:52 AM
RazorN8
Jan 7, 2022 11:44 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
