Alternator pulley installer
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Anybody know a model number and place I can get a alternator pulley remover/installer to work on my GTA? I want to make sure I get the right one since I see quite a few different ones out there, so figured I'd ask here.
Car: check
Engine: check
Transmission: check
Re: Alternator pulley installer
The alternator pulley should be a slip-fit. The stock ones are. Need a 3/8" (5/16" ?) allen wrench to hold the shaft while using a wrench to loosen the nut.
RBob.
RBob.
Engine: 355
Transmission: 4L60
That's easier said than done though. The last time I did this and did it like that, I managed to get the pulley off but couldn't adequately tighten the nut back down because I couldn't get the wrench on the nut anymore once it was so tight, and ended up losing my new OD pulley and an alternator because of it while 3 hours from home.
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Probably not the accepted way but I use an impact gun to zip it off and on. Don't go crazy it just a few zaps while holding your hand around the socket (not the pulley) to keep it from spinning. Been doing it for years and never had a alternator fail.
Car: check
Engine: check
Transmission: check
RBob.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I just use an impact gun. Tightening it down, just zip it down with the gun and let it do a couple of final hits. Torque on the nut is only 80 pounds so you don't need to go overkill tightening it. I doubt I put them that tight and have never had an issue.
The pulley itself is only a slip fit. Once the nut is off, the pulley should just slide off however I have had some that are seized on the shaft. There's no easy way to get one of those off without destroying the threads on the end of the shaft. I've never had any luck with pullers. As long as you're not trying to save the alternator that you're trying to get the pulley off, the easiest way to get the pulley ff is a big hammer on the shaft while holding the pulley.
Most pulleys however should just slide off. Make sure you take the spacer from behind the pulley/fan if there is one.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Impact wrench for me as well. Done dozens of them this way and no problems.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
db057
Aug 11, 2015 10:11 PM
