A/C compressor
Old May 26, 2012 | 06:30 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
A/C compressor
Hi everyone,
Does the r12 refrigerant lubricate the compressor? I would think this is on bearings like the alt. or power steering pump. My AC hasn't ever worked and I bought the spectre air box and the AC receiver/dryer must go to make room for the air tube on that side.
Can I drain the refrigerant to remove the Dryer and keep the compressor installed until I can get the bypass pulley? It might not even have any R12 hence it not working. I think I would be fine but don't want to remove it and take a chance of having the compressor seize up on me.
Thanks in advance
Old May 27, 2012 | 09:24 PM
88 TA GTA's Avatar
Re: A/C compressor
No one can confirm?
Old May 27, 2012 | 09:52 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: A/C compressor
I think there is a separate lube in the compressor. It should not cause any issues if you drain it and leave it bolted up. It's just freewheeling on the clutch unless it's turned on. My compressor has been out for years and I've never removed it and not had any issues.
Old May 28, 2012 | 12:18 AM
88 TA GTA's Avatar
Re: A/C compressor
Thank you!
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
Ironhead38
Sep 7, 2015 02:26 PM
