Build sheet
Old May 28, 2012 | 10:05 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
Build sheet
Found it.
only thing that sucks is that the 4th column is pretty much unreadable. i was able to identify a few of the rpo codes in that column but the rest both the code and description are smeared. Anyone that knows about these if you can give me a hand that would be cool. I know I dont have a rare car but any info you can devulge would be cool.
Old May 29, 2012 | 11:45 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Build sheet
The rpo's should also be on a sticker inside the center console. This is of course assuming its the original console!
Also, look thru here:
https://www.thirdgen.org/forums/hist...-your-rpo.html
Just do "edit/find" on your browser and type in the rpo code and it should show you the code on the page, and where someone has said what it is. I have 60+ codes and managed to find all but 2 or 3. Takes some time, but it was well worth it as i learned alot about my car!
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Magman
Aug 2, 2016 08:32 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Jlanz55
Sep 29, 2015 08:55 AM
