second thought about high pressure oil pump
Old May 29, 2012 | 01:02 PM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
just a quick question about oil pump.
I have rebuilt my 383 "high output" natural aspirated motor.
but I was maybe a little stupid when ordering a oil pump.
I ordered the high pressure oil pump Melling M55A
But after thinking a little I maybe have to do something about this.
I would be just fine with the stock oil pump?
have heard about twisting pump shaft and other damage caused by this pump!
I have new crank shaft and rod's and cam, my clearance in the motor is 0.002 on rods 0.003 on mains.
I have read that it is possible to change the spring inside the pump, is this recommended job to do?
Old May 29, 2012 | 05:08 PM
Re: second thought about high pressure oil pump
That pump isn't going to damage anything.
It's the replacement for the stock GM pump for LOTS of motors over the years, including the L98.
Whatever stories you've heard about ... all that other stuff, are wrong.
Get a Melling IS-55E drive rod, to do away with the plastic collar.
Old May 29, 2012 | 05:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your pump already has a high pressure spring, no reason to change it.
Old May 31, 2012 | 01:36 PM
Car: 87 TA
Axle/Gears: 9"
ok.. thanks sofakingdom and Apeiron
CarGuyDennis
137
Dec 6, 2016 11:02 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
jackhammer
Aug 15, 2015 10:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
