In Tank Pump Mystery? HELP?
Old May 29, 2012 | 06:15 PM
perfprod's Avatar
Car: 1991 Z-28
Engine: 350 vortec
Purchased 1991 Z-28 No motor + trans that owner switched to carb. + installed inline pump,i installed new drivetrain + runs perfect then i parked the car for a few months + car will not start + out of gas because pumps work for 5 seconds when security light is on then quits when light goes out,so disconnect inline pump and run fuel line to gas can + rewire that pump to fan + it runs perfect like before but the in tank pump only gets power when the security light is on so is this a coincident because when i hook all fuel lines back on inline pump cannot pump fuel from tank thru intank pump that shuts off in 5 seconds but i never had this problem driving it before
Old May 29, 2012 | 08:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: In Tank Pump Mystery? HELP?
Oil pressure switch. If you don't generate any oil pressure in the first few seconds of cranking, or if the switch is bad, ( seems more likely for your description ) then the fuel relay circuit stops sending power to the pump.
Old May 31, 2012 | 06:49 PM
perfprod's Avatar
Car: 1991 Z-28
Engine: 350 vortec
i ran separate power to the intank pump + had separate to inline pump,car ran fine until carb ran out of fuel,does anyone know if you can suck thru intank pump if its not working
chazman
Aug 28, 2018 03:25 PM
theshackle
Mar 5, 2017 06:37 PM
Glowsock
Aug 31, 2015 09:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
