are vic jr heads any good?
Car: 82 z28
Engine: 60 over 350
Transmission: 4 speed standard
Axle/Gears: moser 9 inch 411
hi ive got a solid roller 383 all forged10.5 to 1 comp that doesnt seem to have as much power as it should.Carb is 850 motor has less than 1000 miles im thinking the heads arent cutting it is there a better head i should go with?Car is seldom street driven has 9 inch 411 turbo 350 4000 stall only goes 12.2 in quarter 11s with nos any advice appreciated need more speed thanks.Sorry car is 82 camaro full cage .
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: are vic jr heads any good?
The 850 carb is also probably doing you no favors if you have a H/C setup that is not making a lot of power
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
yea more details please. Intake runner size, chamber size etc. Also as the the other person said cam size and specs.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Also, you could be more helpful if you also include your 60' times and your MPH at the top end.
Car: 82 z28
Engine: 60 over 350
hi heads are 70 cc 215cc intake vic jr angle plug
cam is comp cam solid roller xr292 r int dur 292 ex 297 582 lift on int 588 on ex
3200 to 7200
400 0 stall turbo 350
msd dist 36 totalmsd 6al box
1.7 60 ftat 119 mph my times were all over map as was 1st time using nitrous purge stuck on so lost most nitrous
best run was 1.6 60 ft 11.3 at 121 mph figured out that evertime nitrous was activated it would purge but it was to late.Ionly get to race once a year with 3 time trial runs then right into eliminations.
My exhaust is 15/8 shorty that go into y into singl 3 inch but has cutout to open heders but still passes threw y could this b a problem thanks
3200 to 7200
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
I had some Victor Jr. heads...hated them.
Your 60' seams weak...does your car bog any where?
For every .1 removed from your 60' time should give you .2 off in the 1320.
If you over carb a motor it will not run any faster or slower within reason if it's not bogging down from being too rich.
Does your converter flash to 4,000rpm easy at least with that cam.
That cam you need some CR like 11/1 with the 70cc heads hopefully your pistons have a good size dome to get you in the CR for the cams needs.
Exhaust should be fine...imo
Check your timing with a timing light to make sure the advance is where you need it and not sticking.
sorry its late and I'm slowing down....
NinjaNife
Aug 23, 2015 11:49 AM
