Differences between Pontiac and Chevy engines?
Old Mar 27, 2012 | 06:48 PM
ScorchedBird12's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: TPI 5.0 V8
Transmission: 5-speed manual
Axle/Gears: Stock
Friend is arguing that there are significant differences betweent he engines placed in the third gen firebirds and the third gen camaros, specifically the bolt patterns in the engines. I'm aware that there were some differences between the two before 1981. Being raised around GM, I'm pretty sure that after 1981 there were no significant differences between the two engines to the point where one can grab a TPI 350 from a firebird and drop it into a camaro with no muss or fuss. Can anyone clarify this?
Old Mar 27, 2012 | 06:53 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Differences between Pontiac and Chevy engines?
1982-1992 Third Generation Firebirds and Camaros had absolutley no difference in the motors. A LG4 in a Firebird is the same LG4 in a Camaro. Same holds true for LB9, L98 etc...
Old Mar 27, 2012 | 07:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Air intakes were the only differences.
Old Mar 27, 2012 | 07:09 PM
Engine: TPI 5.0 V8
Axle/Gears: Stock
I figured as much. I knew Pontiac and Chevy were rivals pre-1981 so I knew there were differences but after that I knew the only difference between the two would be styling cues.
Old Mar 27, 2012 | 09:51 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
I have people telling me all the time, a camaro is faster than a firebird or the SS will kick a Z28/Transam's ***... I just laugh and say umm humm while thinking, You, sir, are an IDIOT!!!
Old Mar 27, 2012 | 10:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The body styles are different and the third gen f-bodys (pontiac and chev) share many of the same parts but GM went with a corporate engine by the time the third gens went into production. I don't know the exact year but the pontiac, buick and olds engines all stopped production and eventually, so did cadillac. The 80's started losing a lot of brand loyalties. Buy a Pontiac Firebird an Olds Cutlass or a Buick LeSabre and get a Chev engine. No other option was available unless you did an engine swap.
Now if you're talking about the old Pontiac engines compared to the SBC or BBC engines, they share nothing in common in design. It's like trying to compare a chev engine to a ford. A few people with pontiac third gens have done a Pontiac engine swap just to be different but there's no real advantage to doing the swap since it isn't a straight swap. Fabrication and adapting needs to be done but it is possible.
Old Mar 29, 2012 | 06:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
While there wasn't any difference between the engines of the same type between Firebird and Camaro, the Pontiac engine offered in 3rd gens was significantly different than the Chevy engine offered in 3rd gens - the Pontiac engine was the Iron Duke...
Old Mar 29, 2012 | 06:17 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
And didn't the 1989 Turbo Trans Am have a Buick engine?
Old Mar 29, 2012 | 06:41 PM
Engine: TPI 5.0 V8
Axle/Gears: Stock
Yep, the engine from the GNX. Ironically this V6 made this Trans Am the fastest accelerating model. Correct me if I'm wrong, but the numbers were around 0-60 in 4.6 from the factory?
Old Apr 24, 2012 | 11:58 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
4.6 0-60 time in 1989 from the factory? Thats pretty impressive why wouldnt GM want to keep that alive?
Old Apr 25, 2012 | 08:59 PM
Engine: TPI 5.0 V8
Axle/Gears: Stock
Same reason they didn't keep the GNX...it was faster than the Corvette AND much cheaper and would overshadow the corvette in sales.
The question is....why didn't they just make the Corvette faster? *sigh* I wonder sometimes...
Old Apr 25, 2012 | 09:16 PM
Damon's Avatar
Not to worry. They will make sure that never happens again. Ever.
Old Apr 26, 2012 | 04:59 PM
Car: White 84 z28
Engine: Chevy 350
Sometimes I wish they would get over the marketing factor of not wanting to make certain cars better then others and just make the best cars they can make
Old Apr 27, 2012 | 12:01 AM
Engine: TPI 5.0 V8
Axle/Gears: Stock
Which is why I'm all for a new Firebird...though "Chevy Firebird" won't have the same ring to it as Pontiac used to...
Old Apr 27, 2012 | 12:16 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
a new firebird would be atrocious considering how they butchered the camaro..
anyways..the firebirds are "supposed" to be a tad faster than the camaros simply in the matter of aerodynamics but no, not a single difference in the motors omitting the intakes..
Old Apr 27, 2012 | 12:23 AM
Engine: TPI 5.0 V8
Axle/Gears: Stock
Yup....the Firebird GTA had a drag coefficient of .29.....which is supercar territory. And that's also pretty impressive considering that the Bugatti Veyron only has a drag coefficient of .41 - .36.
Old Jun 1, 2012 | 04:41 AM
Torchred87T/A's Avatar
Car: 95 C1500, 91 & 92 Camaros
well the third gen isn't a stretched out Bug now is it
Its much better looking, the Bugatti can do 260+, so what, our cars look like they're doing that sitting still
Old Jun 1, 2012 | 05:16 AM
Engine: TPI 5.0 V8
Axle/Gears: Stock
I'm sure with enough mods our cars can also do 260+....without the need of 10 radiators or $20,000 tires
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
