Blown up? smoke pouring out
Old Jun 3, 2012 | 12:44 AM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
Well tonight i bump shifted from 2nd to Drive racing a mustang outta town when i look in the mirror and a **** ton of smoke comes pouring out from behind the car, the whole front of the motor is covered in oil im guessing i blew a seal out somewhere? i wanna say around the timming chain but im not sure
Old Jun 3, 2012 | 02:51 AM
seawolf18's Avatar
Car: 91 Trans AM
Re: Blown up? smoke pouring out
Blew out the front main, maybe? Clean off the oil, start it up and see where its coming from. Does the engine still have good oil pressure?
Old Jun 4, 2012 | 11:27 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
i think its coming from around the timing chain cover area. the oil pressure gauge says its good but im guessing the gauge is off scince its outta V6 not a V8 and i ran the car about 20 miles and it does just fine until u beat on it then it will smoke alittle bit and drip alittle oil. im going to clean the area alot better tomoro and go from there
Old Jun 5, 2012 | 11:04 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Sounds like a front main seal, but I could be wrong. Does the smoke come out of the exhaust or is it just the oil burning off the engine and blowing back?
Old Jun 5, 2012 | 11:30 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Sounds like a front seal to me, clean it up, make sure it has oil in it and see where the oil is coming from. Its possible to change the front seal by just removing the balancer, but its not a fun or easy job.
Old Jun 5, 2012 | 11:34 AM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
its gotta be burning it off the motor or header, because it does drip alittle after beating on it. so is the front seal around the timing chain cover?? i really dont wanna tear down the front of the motor to fix it scince im starting to build a 350 for it and dont wanna put any time/money into this 305
Old Jun 5, 2012 | 06:36 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Clean all the oil off with degreaser, and watch it real close to find the leak. If it's up front, could be front seal, rocker covers, china wall.
If you don't feel like fixing it, then don't beat on it
Old Jun 6, 2012 | 12:55 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Exactly
Old Jun 6, 2012 | 07:50 AM
2007xl50's Avatar
Engine: LB9/3.1
Like was said if you don't want to fix it and you have a 350 you are working on then clean the leak area up, keep an eye on the oil level and try not to beat it too bad till the 350 is ready to go in.
FormulasOnly
Jul 23, 2018 08:47 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
383backinblack
Sep 25, 2015 11:31 AM
KCG
Sep 23, 2015 09:05 AM
