Fuel Pump Question
Old Jun 6, 2012 | 07:29 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Fuel Pump Question
Looking to replace the stock fuel pump. Is it possible to get a fuel pump that will help add performance- power/torque? If so, is there other considerations to think about if making a change to a high-performance pump versus a stock pump (law of unintended consequences applying?) Is it worth the price difference?
Current setup:
1984 TA
L69 HO V-8
New/Remanfctr Q-Jet
Everything else stock as well.
Thanks!
Chuck
Old Jun 6, 2012 | 08:36 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: Fuel Pump Question
not really, you can only burn x amount of fuel. having said that if the stock pump isnt supplying enough fuel and or pressure then yes. with your set up a stock pump is plenty IMO
Old Jun 6, 2012 | 09:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Air is what limits engines, not fuel.
Old Jun 6, 2012 | 09:54 AM
Chuck84TA's Avatar
Additional air --- Makes sense, I guess I thought if you operate at WOT with the secondaries fully open that a possible impedence to additional performance would be a lack of adequate fuel pressure from a stock pump that may be limited in pressure output, because it's "just" stock. So apparently from what has been said ..... for a stock engine like mine, the stock fuel pump is adequate.
Old Jun 6, 2012 | 10:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Even for many non-stock engines a stock fuel pump is more than enough.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
