Strange sound when I turn off the car...??
Old Jun 6, 2012 | 10:17 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So yesterday when I tried to turn on the car it took longer than usual becuase I had to constantly turn the key and hit the gas so that it can turn on and maintain the throttle so that it wouldn't die on me....
Then when I went to park to car, i turned the key like always and it made this weird noise......it kinda seemed like the engine didnt wanna turn off and then it just made like a noise that trains make when the come to a stop, like a loud hissing noise, it sounded bad, but idk what it really is or if i should be worried.
I made a video of it but the volume is a lil low hopefully it helps..
http://s55.photobucket.com/albums/g1...605_195404.mp4
Old Jun 6, 2012 | 11:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Strange sound when I turn off the car...??
Just sounds like a little run-on, not really a worry unless it carries on for several seconds. Timing or idle mix maybe a little off, or there's a bit of hot carbon deposit stuck in a chamber somewhere. Given your description of how you have to start it, it's probably tune-up time.
Also sounded like a lifter or something ticking when you were in the car, but it seemed to disappear when you moved outside?
chazman
Aug 28, 2018 03:25 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
B_Dubya
Aug 26, 2015 05:09 PM
red90IROCls1
Aug 25, 2015 06:56 AM
TheExaminer
Aug 19, 2015 10:07 PM
