85 Z28 Starts then dies
Old Jun 7, 2012 | 02:33 PM
zzjakect's Avatar
Car: 1985 Z28
My 85 Z28 with a 350 (1987) TPI has developed a terrible problem It ran fine until about a week ago. Now when trying to start the car it fires-up, idles for a few seconds and then dies. It will occasionally run for a minute or so at about 900 RPM. Then the RPM drops to about 700, the car sputters and dies out. At this point it will not restart unless it rests for a while. I checked vacuum lines, changed plugs and wires to no avail. I think the next step would be the cap and rotor? It has a new fuel pump (PIA!).
Any info on the steps I should take to troubleshoot this would be greatly appreciated. Thanks.
Old Jun 7, 2012 | 02:51 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 85 Z28 Starts then dies
See if the spark is dropping out when it dies by using an inline spark tester attached to one of the plug wires. If so, it is likely the ignition module. If spark is okay, check fuel pressure to verify that the fuel pump or control circuit isn't dropping out. If fuel pressure and spark are okay. It is likely that you have a MAF sensor or MAF power module issue. You will need to do some testing for MAF signal voltage to the ECM to verify this and what is the exact cause.
Old Jun 8, 2012 | 02:58 PM
zzjakect's Avatar
Car: 1985 Z28
Thanks for the ideas. Where is the ignition module located?
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
