CC of stock heads?
Old Jun 8, 2012 | 07:16 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
CC of stock heads?
I'm just wondering what the cc is on a cast iron stock 305 head so I can compare it to an aftermarket one. Namely trickflows. I was told 175 would not cut it for a 350... but would they work for a 305?
Old Jun 9, 2012 | 10:31 AM
Vader's Avatar
Re: CC of stock heads?
Intake runner volume? Stock heads are as low as the 150s for a 350, and even the stock aluminum L98 heads were only in the low 160s. If you are planning to run EFI or carb on the street, the smaller runners are acceptable. If you are going to the track and will see much higher RPM you might want more volume, but you'll also need a lot more gear.
Old Jun 9, 2012 | 10:41 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
the combustion chamber on the trickflow 175's is 56, do you know what the cast iron heads were?
Old Jun 10, 2012 | 05:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I believe stock 305 combustion chambers are nominal 58cc's.
Old Jun 10, 2012 | 09:53 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
would trickflow 175's be too big for the 305? or would it just make it breathe easier
Old Jun 11, 2012 | 12:17 AM
turbofire327's Avatar
Has anyone actually cc'd the chambers on some stock heads, I know they are all slightly different depending on casting number. 434, 416, 450, 601, etc.
Old Jun 11, 2012 | 12:19 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
interesting... must do further investigation.... Don't have the tools to though
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
