Fuel Pump Keeps Running - Killed New Battery
Car: '09 Pontiac G8 GT - 12.76@109
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
Went outside today to start the car and it was dead. WTH? It was just perfect on Sunday.
After jumping it and shutting it down, I noticed that the fuel pump just keeps running even when car is off and key is out. Didn't take me long to figure out that the pump running killed the battery.
So what would be causing this? Fuel Pump Relay? Oil Pressure Switch? Fuse to Battery?
Any help is appreciated.
Engine: 4++,350 & 305 CIs
Re: Fuel Pump Keeps Running - Killed New Battery
Tap on the relay or unplug it to see if its that stops the pump
If it stays running it could be the oil psi switch.
Pull the fuelpump/ ECM fuse if all else fails!
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
Nothing worse than reading a thread and never hearing back from the person as to what the final cure was. For me, I replaced the fuel pump relay and the oil pressure switch. The oil pressure switch was the culprit.
END.
END.
Car: 1992 Camaro RS
Engine: 305 TBI
I also like to hear feedback when an issue is resolved. Thanks for the update!
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
