camaro dies and now there is no spark
Old Jun 14, 2012 | 07:21 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hello, so last night I went for a drive in my 84 camaro. About an hour from home I crossed a set of train tracks and the car stalled. Now the car will not start at all and I have no spark either. So I hopped in my Durango and drove back early this morning and gave it a try and right away Vroom it came to life and then just as quickly it died again. I have one of skip whites HEI distributors and it is the clear/transparent one and I can see that there is no spark going on in there. Does this sound like it could be the coil? Any ideas would be great. Going to get it towed in about an hour and am hating the thought of the tow bill. Just a side note, it was dark when I was trying to start it last night and I could clearly see that there was no spark at all......but then it fired up briefly this morning....so then that means it had spark after sitting all night. Does that mean something?
onthedownlow
Old Jun 14, 2012 | 08:30 AM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: camaro dies and now there is no spark
theres a possibility that the ignition coil is heat sinked and not operating, then when cooled works. pretty common. but the pick up coil inside the distributor has the same symptoms but temperature doesnt effect it as much, it just breaks down and gets intermitant open circuit.
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
apo_bailon15
Mar 28, 2016 05:20 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
