Which set up to go with?
Old Jun 17, 2012 | 01:20 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Ok I have these two engines laying around and I dont know which one to put in my 92 camaro
First engine : 355ci roller block with dome pistons,Etec 200 heads,edelbrock performer rpm air gap,oil pump high volume,226/226 .525/.525 lift on 1.5 rockers(got 1.6 rockers laying around might put them on ) and 650 street HP holley carb
Second engine : 383ci mahle pistons flat top two valve reliefs,6" rods,internal balance roller block,timing gear,oil pump high volume,harmonic balancer 0 weight along with flywheel 153 0 weight,AFR 210 eliminator heads (AFR-1054) ,LT4 hot cam and thinking of going for more aggressive cam,edelbrock performer air gap
Now I have an '82 stepside shortbed C10 and I dont know which one to go with for the truck and the Z28 both have TH350 and B&M holeshot 3600 stall what do you suggest?
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
