Temp capping off fuel lines
Old Jun 19, 2012 | 10:55 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Hey Guys,
I'm installing new heads and intake, I've capped off the fuel lines with vacuum hose caps and taped them up with electrical tape.
Is there a better way to do this, as I'm working on the top end when I get time and don't want a puddle of gas under the car.
Follow up question, one of lines is a vent line....should this not be capped?
Last edited by 89transam*pearl; Jun 19, 2012 at 11:52 AM. Reason: follow up question
Old Jun 19, 2012 | 12:00 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Temp capping off fuel lines
I capped them and the fuel expanding with heat in the tank popped them off and made a mess. Then I joined the supply and return lines with a short piece of hose and some clamps and it was all good.
Old Jun 19, 2012 | 12:39 PM
Car: 89 T/A
Engine: LB9
Thanks, i'll do the same.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
