How do I adjust the ignition timing on a stock L69 with stock HEI?
Old Jun 22, 2012 | 10:31 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I can't seem to find the procedure for this. There is one posted in the "technical" section but it has to do with FI engines.
Chuck
Old Jun 22, 2012 | 10:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: How do I adjust the ignition timing on a stock L69 with stock HEI?
Exiting the distributor is a 4-wire cable with a connector on it. Disconnect it to prevent the ECM from adjusting the timing. This will set code 42, that is normal.
Can now set the base timing by rotating the distributor and using a timing light. It can be tough to get the the hold down bolt, it is a 9/16" hex head on the bolt.
Be sure to adjust the timing on a warmed up engine, and recheck once the bolt is snugged down.
RBob.
Old Jun 22, 2012 | 12:16 PM
Chuck84TA's Avatar
Thanks RBob!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
stalkier
Aug 7, 2015 04:49 AM
