oil
Old Jun 29, 2012 | 06:13 PM
jesse1957's Avatar
Car: 82 z28
Engine: 305,eldelbrock cam and lifters, per
Transmission: auto
Axle/Gears: 352
oil
i pulled the exhaust manifolds of my 82 z28 305 to put headers on it, the heads were rebuild and new performer manifold,and cam and lifters, runs good ,plenty of power, no water in oil, or oil in water, anyway number 3 and 5 exhaust ports are coated with oil, i noticed that it will blow a little blue smoke now and again but quickly goes away, my plugs are really clean, no oil on then,, could it be a intake manifold leak? or maybe the head gasket? i torked then in sequence at 65 lbs.anyone have any ideals i,d be glad to hear them,,,jesse1957
Old Jun 29, 2012 | 09:21 PM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: oil
Personally, I would look at your valve guide seals. They are fairly easy to change with the motor all together in the car.
Old Jun 29, 2012 | 11:50 PM
jesse1957's Avatar
Car: 82 z28
Transmission: auto
Axle/Gears: 352
Re: oil
well, i paid 400 to have them rebuilt two months ago and they replaced the valve seals, if they are leaking i,ll give them hell. i just got done putting headman headers on it about an hour ago. lucky that the exhaust shop is a half mile away,,, he said he would weld them up for me for 150,,, thanks for the advise, i might just pull the head again and take a look. jesse
Old Jun 30, 2012 | 07:26 AM
Re: oil
No need to "pull the head" to do valve guide seals. All you need is a spring compressor which you can "rent" at alot of parts stores, or buy cheap if you think you might use again.
If the ones that are on there are "umbrella" type, or just the stock O-rings, get rid of them, and put on "positive" type ones. http://shop.advanceautoparts.com/web...CGRP60011_____
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
