same boring fuel pump question
Old Jul 1, 2012 | 01:05 AM
zzjakect's Avatar
Car: 1985 Z28
Tested the fuel pressure at rail 10 PSi . Ordered new fuel pump (ACDELCO). Should I replace fuel pressure regulator too? Where does it go? Yeah I'm a NOVICE. The car will start and run using starter fluid so I guess it is not an electronic issue. The pump is wired to a switch tied to ignition so it is always on when car is running. Please help. I appreciate your vast knowledge base.
Old Jul 1, 2012 | 01:36 AM
Roc Me 2's Avatar
Car: 1989 Iroc
Engine: In the works!!!
Axle/Gears: 9-bolt, 3.73 gears
Re: same boring fuel pump question
I would just replace the pump at this point. Have you tested the regulator?
Old Jul 1, 2012 | 02:42 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
TPI, TBI or carb???????
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
