Starter?? wont start when hot IROC-Z
Old Jul 3, 2012 | 10:28 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
i have a 86 iroc with the stock 305 tpi set up and the last 2days ive been driving it the car will start fine from a cold start but once it gets hot like after i get to work or drive it a few miles and i shut it off it wont start it kinda cranks over alittle then stops and it will do that until the car cools down alittle i normaly have to wait 20min or so before it will fire again, i was thinking the starter for sure but what i do understand is why it does it after everything is warmed up and not when its cold. i really need this figured out if its the starter because im droping a 383 in it in a few weeks and dont wanna but a junky starter on it.
Thanks guys
Old Jul 3, 2012 | 10:45 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Starter?? wont start when hot IROC-Z
Heats a killer...If there are no other issues with the engine, it sounds like a weak starter to me. If no other issues, do a load test on the battery but plan on putting in a new starter.
Old Jul 3, 2012 | 11:12 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
maybe it is the heat my fan quit working and its been in the 90s the past few days.. dont really wanna buy a new starter and run it on this motor for a few weeks then take it off again
Old Jul 4, 2012 | 02:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by IroczFan
maybe it is the heat my fan quit working .. dont really wanna buy a new starter
So fix your fan so the engine doesn't get so hot then
Old Jul 4, 2012 | 05:27 AM
Twin_Turbo's Avatar
GM sells a brown starter solenoid, it's a high heat model, has better/thicker wiring. Cheap fix!
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
