need help. loud pop! loss of power.
Old Jul 6, 2012 | 01:11 PM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
I have an 89 tbi. When driving there are loud pops under car, accompanied by loss of power and stalling. Car will start right up if attempted. I let it cool. Also have a code 23.
Old Jul 6, 2012 | 01:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: need help. loud pop! loss of power.
Sounds like spark drop out. The popping in the exhaust is unburned fuel igniting as it hits the hot exhaust manifolds. Suspect a failing ignition module.
Code 23 is manifold air temp sensor or circuit. The sensor on your TBI car should be in the air cleaner. Is yours connected? This code will most likely not be related to the popping and stalling.
Elephantismo
Feb 13, 2019 12:51 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Racerx974
Sep 19, 2015 10:16 AM
Randomtask2
Sep 10, 2015 08:37 AM
middian
Sep 5, 2015 01:42 AM
