Will this 350 swap work with my TPI?
Old Jul 9, 2012 | 12:22 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
Hey guys will this 350 work with my TPI? I currently have a 305 tpi engine. I have a Edelbrock tpi intake and polished/ported slp runners and ported plenum. Here are the specs for the 350. I can pick it up new from a friend for 2,000. Any help would be appricated.
What will I need to do to use my computer?
https://www.yearone.com/Product/DisplayProduct/227093
Old Jul 9, 2012 | 06:48 AM
Re: Will this 350 swap work with my TPI?
1. Any "400+ HP" 350 will have a cam unsuitable for TPI.
2. That motor says it has Dart iron Vortec heads; your TPI base plate won't fit it.
3. Again on the heads, they most likely don't have the EGR passage, and without a working EGR, you won't pass inspection.
In short, doesn't look like the right motor for you.
Old Jul 9, 2012 | 09:03 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Thank you for your response sofakingdom, I wont waste my time.
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
