'85 w/ '90-92 harness oil pressure switch question
Old Jul 11, 2012 | 06:21 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I'm in the process of swapping out my engine & ecm on my 1985 Camaro, I changed over to the MAP-style ECM/wiring harness and I have a question.
When I removed the old engine, the place where the oil pressure switch was installed was kind of a disaster - they had multiple adapters and tees with at least two different sensors running off of it. I assume one was for the fuel pump and the other for the gauge.
The new wiring harness came with instructions that called out a very detailed oil pressure switch (ECH OP6660), which I got from Napa. However, on the Napa website it lists this part twice - once it says "fuel pump pressure switch" and for the other one it says "oil pressure light switch".
So...is this the only switch I need? Or am I going to need a second one for my gauge? Not sure if it matters but I'm going to be installing an AutoMeter oil pressure gauge once the engine is in.
Old Jul 11, 2012 | 07:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: '85 w/ '90-92 harness oil pressure switch question
Two type of 3 pin sender units available; one works with idiot light , the other with pressure gauge
(other 2 pins are OP switch for pump )
http://www.motorcityreman.com/generalmotors14.html
Autometer may require it's own special sender unit, check first
Old Jul 11, 2012 | 08:20 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Thank you for the response, but I'm still confused. How do I know if the one I have runs a light or gauge? The GM cross-reference is 25037045. If it runs the gauge, I won't need a second one, right? Unless AutoMeter says they need a specific sending unit (which I don't think the meter I have does, if my memory serves me correctly).
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
squiggy2
Aug 9, 2015 09:30 PM
