Starter clicks and positive on battery red hot
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I think it my starter but i wanna see what you guys think, normaly on cold starts the car will start just fine then after driving it after u shut it off and try to start it again it barly with turn over then stop or as of today it didt turn over at all even when cold when it normaly will start it just clicked everytime and the positive on the battery started to glow and started smoking i dont even think it will click now and i have battery power to everything else so its gotta be my starter right??? u should probly know it is covered in some oil scince i have a bad oil leak up front so im guessing that is causing it to act up and maybe even fry its self, id like to get some opinions before droping $160 on a starter
Car: 86 IROC-Z
Axle/Gears: 3:42
Re: Starter clicks and positive on battery red hot
and its not the battery being dead its only a month old
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Spend $75 on a reman starter at autozone with the lifetime warranty. It sounds like once the starter gets warm ( probably due to it being close location to the manifold/header) it stops working. Mine fails like this once every ~6 months. So Ive stopped buyin performance starters and bought a cheap one. Now I just exchange it when it fails for a new one every time.
Going with the assumption that your battery is not the problem:
The starter motor draws a lot of amps, which crudely defined is the number of electrons passing through the circuit. When your positive battery cable gets hot, it indicates that the ampacity of the conductor is not adequate. That is, if the resistance is high due to having too small of cross section area and a high ampere draw, then all the electrons trying to get through that area will generate heat which raises the resistance more. So, my guess is that there is corrosion around the positive battery post. Possibly the corrosion is hidden under the cable's insulation. If you were me, you'd check the cables and replace with a higher gauge (thicker, lower number) cable if needed.
Car: 86 IROC-Z
Axle/Gears: 3:42
ended up buying a new starter not a cheap one either, im gonna put it on the car and see what happens other wise trailer it to where i need it to be and tear the motor out for a swap
Before outsmarting yourself to that extent, replace the batt cable.
You'll probably find that the starter makes no difference whatsoever as well.
Oh well, sometimes learning stuff ends up costing money.
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Yea, agreed... I think the cable needs to be switched out. Chesterfield did a good job explaining that too.
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
db057
Aug 11, 2015 10:11 PM
