86 TPI fuel lines
Car: 86 Iroc-Z
86 TPI fuel lines
building an 86 iroc i picked up for cheeeeep...needs the majority of the fuel lines replaced, buuut im having trouble locating the lines from any and pretty much all sources
. does anyone know of places that custom make fuel lines that will bolt right up like a factory replacement? id rather have a tight factory fitting on the pressurized fuel lines then a repair kit...any input is greatly appreciated. thanks!
. does anyone know of places that custom make fuel lines that will bolt right up like a factory replacement? id rather have a tight factory fitting on the pressurized fuel lines then a repair kit...any input is greatly appreciated. thanks! Senior Member
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: 86 TPI fuel lines
You are having trouble finding lines to replace yours?
Have you checked ebay?
http://motors.shop.ebay.com/i.html?_nkw=tpi+fuel+line
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Hope that helps
Hope that helps
Car: 86 Iroc-Z
yes ive checked pretty much everywhere...none of those lines are the ones that i need, 1 member in a different thread mentioned a site inlinetube.com that lists a set that i ordered, no diagram tho...so im hoping the kit which includes 3 brand new oem matching main fuel lines includes the line...thanks a lot for narrowing an ebay search for me tho!!
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
