86 iroc z stalls when I push the gas pedal
Car: 1986 camaro iroc z, 2001 Isuzu troo
Transmission: auto
Hello I have a 86 iroc z with the 305 tpi in it. My problem is that it starts up perfect everytime and then when you push the gas pedal to move the car stalls. The computer has been changed along with fuel filter, and maf sensor. The fuel pump starts up and you can hear it fine. It does have a small gas leak, could that be causing all this problem??
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: 86 iroc z stalls when I push the gas pedal
Never a good idea to drive a car with a gas leak! It depends on where the leak is coming from, but that could definetly be your problem. Get that fixed ASAP
After that if the problem persists, id start by checking the TPS.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
TPS, fuel pressure, vacuum leaks. Look for a severe KV leak at the coil wire or a damaged coil tower.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Aug 11, 2015 03:17 PM
